Manual Input of warning limit
Is there any way that I can set the warning limit different than using Resources-> Warning Limit in %
If I use this option it will calculate the warning limit around the center of the tolerance, but I don't necessarily find this as the best solution in terms of our process.
Can it be done in other ways?
https://qualityforum.zeiss.com/topic/5452-manual-input-of-warning-limit/
  • 2 years later...
