get the number of points in a curve
Hello everyone,
Is someone knows if we can use the PCM to get the number of points in a curve ?
I want to compare a min or max point with the first and the last points of a curve.
Create a point from the first is easy : you just have to put "1" in the box of the number of the point.
But to do the same with the last point is something I can't do (yet ?...)
(something like : "firstpalletlocationnumber" or "lastpalletlocationnumber" but for curves)
Thanks !
https://qualityforum.zeiss.com/topic/5460-get-the-number-of-points-in-a-curve/
