[Da...] Posted June 12 Share Posted June 12 Hello everyone, My question is why does first feature that is measured after CP acts as its still CP even though I set it to SCP? For exemple I want to measure 3 Space Points, first goes form CP +X, second and third from SCP +X and first is measured normaly but second is also measured the same as the first (going out of my clearance plane) and then third is measured as it should be (going from second to third without leaving clearance plane). I am currently CALYPSO 2020 , ServicePack 2. Thank you in advance. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 12 Share Posted June 12 2 Features in a row have to be on the same Sub Clearance Plane for them to be used. So if you set all 3 points on the same sub clearance, the First should come from the Parent Plane +X, then 1>2 and 2>3 should stay on the Sub Clearance, then after 3 it should move back to the Parent, assuming thats the last feature on that Sub Clearance Plane Link to comment Share on other sites More sharing options...
[Ab...] Posted June 12 Share Posted June 12 some information on SCP https://portal.zeiss.com/knowledge-base?id=1793299 Link to comment Share on other sites More sharing options...
[Da...] Posted June 12 Author Share Posted June 12 Please sign in to view this quote. The first one is lets say CP+X because it has to move out of Plane and second two are SCP+ because they are close to the first one so they will be measured faster. Are you saying that all 3 should be SCP+X for that to happen? Link to comment Share on other sites More sharing options...
[Mi...] Posted June 12 Share Posted June 12 Please sign in to view this quote. Yes all 3 need to be on the same if you want it to move like that. Having the First point on +X will make it move to +X Clearance before and after the measurement. Link to comment Share on other sites More sharing options...
[Da...] Posted June 12 Author Share Posted June 12 Thank you very much, just one more question 🙂 do you maybe know was like that in older versions of calypso? Link to comment Share on other sites More sharing options...
[Ca...] Posted June 12 Share Posted June 12 Hello - It has been like that for quite some time, since at least CALYPSO 5.0. Link to comment Share on other sites More sharing options...
[Da...] Posted June 12 Author Share Posted June 12 Please sign in to view this quote. Thank you Link to comment Share on other sites More sharing options...
