[Mo...] Posted June 5, 2024 Share Posted June 5, 2024 Dears, do you know if it is possible to add tolerances into nominal coordinate list (txt. data) (Solldaten)? Especially considering tooth thickness tolerance and topographical tolerances. Alternatively, would you be so kind sharing examples for nominal coordinate lists (txt. data) (Solldaten) as picture or txt file? I am looking forward to your help. Link to comment https://qualityforum.zeiss.com/topic/5474-bevel-gear-gt-is-it-possible-to-add-tolerances-into-solldaten-nominal-cooridinate-list-txt-file/ Share on other sites More sharing options...
[Ro...] Posted June 5, 2024 Share Posted June 5, 2024 Hi, it is not possible to add tolerances. And example you´ll find attached.GEAR PRO bevel pinion.txt Link to comment https://qualityforum.zeiss.com/topic/5474-bevel-gear-gt-is-it-possible-to-add-tolerances-into-solldaten-nominal-cooridinate-list-txt-file/#findComment-19554 Share on other sites More sharing options...
[Mo...] Posted June 12, 2024 Author Share Posted June 12, 2024 Dear Roman, many thanks for your answer and your sample nominal data. It is a pitty that Tolerances can't be added to nominal data. Link to comment https://qualityforum.zeiss.com/topic/5474-bevel-gear-gt-is-it-possible-to-add-tolerances-into-solldaten-nominal-cooridinate-list-txt-file/#findComment-19556 Share on other sites More sharing options...
