Result Input nominal doesn't match PiWeb report
I need to measure a swage on a copper tube with a pin gauge at the end, after all other characteristics are measured.
I set up a Result Element like this:
In the PiWeb report, though, the nominal is not the same. What am I missing?
Piweb appears to be converting the nominal and tolerance values to millimeters for some reason. I can't replicate this in Calypso 2020, though, unless you're looking at this report via the Reporting Plus application. When my Contura was still on 2020, reports called up at the end of a measurement run would display correctly, but when I accessed the data through that application it would always convert to SI units.
It's a bug in Calypso. Try the following formula for your nominal entry "0.255*0+0.255". That should do the trick, update accordingly and repeat the process for your tolerance. Let me know if that works for you
  • 3 months later...
