How to use re-measure in pcm?
Hello, everyone.
I have a question.
If a characteristic is "False", is it possible to re-measure only that characteristic?
ex. if Roundness_hole_5>0.002 then
positionCMM(getPositionCMM().x,getPositionCMM().y,-500)
message("Clean Probe")
Delete = getActual("DIN Round_hole_5")
measure("DIN Round_hole_5")
endif
endif
https://qualityforum.zeiss.com/topic/5490-how-to-use-re-measure-in-pcm/
Yes I think this is very possible.
I think it would be better to check something else rather than "if a characteristic is false', you can check if it is out of tolerance, or if something related to the feature is too high or low, such as size or form.
Then you wouldn't want to delete the feature or characteristic, perhaps only delete the actuals associated with the feature (ME) or characteristic (CF).
You could then measure again with similar PCM as you have posted including the code : measure(Circle hole 5) for example.
Hi,
just found out that there is an example in the calypso online help for exact this case: πŸ˜ƒ
So maybe this will help you:
// Measure Circle hole_5 , check roundness; if out of tolerance, interrupt CNC and request next
// task: repeat feature or measure next feature or terminate CNC run.
// Defining starting conditions
status_5 = 2
hole_5 = getActual("DIN Round_hole_5").actual
// If out of tolerance, open a window and inquire CNC End, Continue or Repeat
if hole_5 > 0.01 then
message("DIN Roundness of hole_5 is:" ,hole_5)
status_5 = inquire("1=CNC-End, 2=Continue, 3=Repeat. Enter a number")
   message(status_5,"Is your entry correct?", "DIN-Roundness of hole_5 is", hole_5)
      if status_5 == 2
         then
         message("CNC run will be continued")
      status_5 = 2
      endif
endif
if status_5 == 1 then
   message("The CNC run will be terminated due to excess tolerance in hole_5.")
   cncBreak()
endif
if status_5 == 3 then
   message("The circle measurement is repeated.")
      if LOOP1 == 5 then
         message("CNC run will be terminated due to too many loop runs in hole_5.")
         cncBreak()
      endif
endif
print("Status is",status_5, "DIN Roundness of hole_5 is", hole_5)
Thank you for answer πŸ˜ƒ
Anyway, I already tried the information you gave
There were some problems.
1. In that method, the alignment is measured again.
2. Measurement results ​​are output as many as the specified number of loops.
If a characteristic out of tolerance during measurement, I want the measuring instrument to stop for a moment,
remeasure only that part, and then measure the next characteristic if it falls within the tolerance.
I tried several times today,
It seems to have been a success.
I'm definitely planning on applying it tomorrow.
Tolerances were applied to the characteristic conditions,
The repeat/until condition was used.
  • 1 year later...
  • 2 months later...
