Cmposite Position Basics
In addition to our machinists using the actual values of basic dimensions for machine adjustments, we have many customers who require actual values of basic dimensions be reported as part of the position. Usually this can be accomplished with the "additional report" setting. I haven't been able to define a pattern to use that reports these basics between the features instead of from the center of the pattern with either polar or cartesian distances. I am looking for the particular setting that would display basics between the features as part of the pattern.
For the top tier, since you have a fully constrained DRF, you can do 3 position characteristics or 1 best fit bore pattern. For the lower tier, you need to use a best fit bore pattern, allowing translation and rotation. Personally, I would use best fit bore pattern for both due to the ability to create plots. I would un-tick the rotation and translation best fit options for the top tier.
Interesting that the additional printout doesn't export the coordinates for excel... We don't use the excel prinout period, I expect not many do.
Use a result Element to report the basics
In the Nominal put: getNominal("Position Name").coord1
if the formula put: getActual("Position Name").coord1
coord2, coord3, etc.
Note: If you use a BFBP the syntax becomes getActual("Position Name^1").coord1
And if that BFBP is set to polar this doesn't work and I don't know why.
Another option is create your BFBP as the control frame says, and then recall all your holes onto the new alignment that BFBP will have made, then just report the coordinates directly... lots more work, but it'll do it.
Well - i would understand for machining purposes, but often you can not place tolerance to positions due drawing ( like here )
I had an issue with QA - i did comparison of deformed part with machined model created from drawing without dimensions if it can be machined with non missing material. They always want graphical presentation - so I've used profile without tolerance ( due to different material surplus ) - i could not explain them why there can not be used tolerance 🤣
Martin,
I appreciate your question. While not a direct answer, here is an outstanding video by GD&T Basics that explains the difference between Composite Position and Position with Multiple Single Segment Tolerances.
https://www.youtube.com/watch?v=IBb65qSpO_U
We don't use Excel Printout either. I wrote a VBA macro that imports results from table file into our first article report based on the characteristic name. For example balloon number 51 would have a corresponding characteristic named 51-Something and this way the macro knows what to import. I like it because its universal for every first article and every cmm plan and in a job shop it works great. But the with actuals of GDT the problem is that I can't change the name of the record to the same format.
Your suggestion to use formula with coord is great I will try to get that to work.
Thank you!
