CMM don't let me START Mesurement select other Manual RUN
Hi i have problem with calypso why don't let me select on START MESUREMENT other than Manual Run I can select cad of part and open it but when i go CMM on combo box Manual Run, i click there and don't show nothing jus Manual Run, other combo box also happen same thing don't let me select, so to setup new part for mesurement i don't create a new part setup, you ca see on attach files...
some setting are wrong or that is going on..
Any help wellcome
Thanks.
Hello Enrique,
Have you run a manual alignment on this part yet? Or perhaps might the basesystems folder got deleted or something? This sounds like it doesn't have any information on that alignment if you can't use that drop down. You can theoretically use the base alignment menu to do a manual alignment and perhaps it would show up then. I would think the alignment drop down should have something in there, though, which makes me wonder if that folder got deleted or moved somehow, but that being said it also looks like an older version, so perhaps that was limited back then.
I hope that helps.
Well i think i can open cad file to show part must be show on drop down why don't don't show up why don't nothing con dropdown box, how i can check folders settings or assign folder for mesurement....
yes is old version witch one is i don't know but is not recently just i started to do this...
Thanks for your help
Enrique Pineda
Open the base alignment window and close the window. The base alignment should show up in the dropdown menu of run window.
