[Ti...] Posted November 18, 2021 Share Posted November 18, 2021 Dear community, I would like to measure the surface roughness of a part. How can I do that using GOM Inspect? Here is a screenshot of my current view, I was able to import my point cloud. Link to comment Share on other sites More sharing options...
[Na...] Posted November 19, 2021 Share Posted November 19, 2021 Hello Timo, you could create a surface defect map on your surface. If there is a surface comparison of some kind in your project, the check "form change rate" may give you an idea, too. Your mesh has a lot of holes, though. So the inspections might not work out as expected with a clean mesh. Judging from the color in your screenshot, the surface's normals are inverted, too (if we are looking at the outer surface). This can be changed under operations -> mesh in the menu. Regards, Nanno Link to comment Share on other sites More sharing options...
