Auswertung an Kugel?
Easiest way would be like this. [list=]
  • Measure planes and sphere.
  • Make new alignment where you use Plane as Spatial with +Z axis
  • Use Caliper distance [list=]
  • change alignment to previously created
  • set Minimum from Geometry for sphere
    You could also construct a perpendicular from the plane to the sphere and ask for the length of the perpendicular. No need for additional alignments.
    Then he would need to use Result element to get second length ( R - perp length ) as he has in drawing.
    No, there is a perpendicular Depth check box in the perpendicular FEATURE. (not the characteristic) the second length would just be another feature. Oh Wait, you're correct, a results element would be require!
