unilateral profile results .020 U 0 ABC
My customer is expecting to see a negative result on the CMM report when I'm reporting a Unilateral Profile .02 U 0 ABC.
Is this correct because I keep get results within .02 but always reported in a + number. I have set my calculations to Unilateral inside.
Any help would be greatly appreciated.
Use Bilateral with two results.
You'll get a min and max with -0.02 end +0 tolerance which should satisfy the customer
If there is no note on drawings, then it should be "Bilateral with unequal distribution - one result".
For reporting only one number you would need "Outwards / Inwards to infinity" - but i think it will always be positive and not unequal distributed.
As Michael mentioned - you can use "Bilateral with unequal distribution - two results"
Or use "Result element" with formula "getMaxActual("Profile1").actual" or "getMinActual("Profile1").actual"
Image aid
viewtopic.php?p=47346#p47346
