[Da...] Posted December 19, 2023 Share Posted December 19, 2023 I'm looking to mount 2 probes about 75 mm apart on the same side of a probe "bar"? Where can I get a bar that looks like a stretched 20 mm cube? I thought I saw them in the probe shop but can't seem to find them. Link to comment Share on other sites More sharing options...
[To...] Posted December 19, 2023 Share Posted December 19, 2023 Please sign in to view this quote. Not sure about the 75mm apart...... https://shop.metrology.zeiss.com/INTERS ... ation=true https://shop.metrology.zeiss.com/INTERS ... ation=true Link to comment Share on other sites More sharing options...
[Ke...] Posted December 19, 2023 Share Posted December 19, 2023 I do not see the items on the webshop either, but you may be able to find what you are looking for in Stylus System Creator, probably in the “connecting elements->cube” section, and from there you can get the part number(listed as order number in SSC) to contact our aftermarket sales team and inquire about ordering. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 21, 2024 Share Posted May 21, 2024 Would a setup like this work? (Add counter balance as needed). The setup utilizes two Rotary Joints that allow easy alignment of each Cube, Or it may give you ideas. See attached PDF and SSC files. Rename the "Test.ssc.txt" file to "Test.ssc".Test.ssc.txtTest.pdf Link to comment Share on other sites More sharing options...
[Da...] Posted May 21, 2024 Author Share Posted May 21, 2024 Thanks Rick, but we ended up making our own out of Titanium. Link to comment Share on other sites More sharing options...
