Hoping to Find Reduction of Area
Hello all, I am hoping to calculate % Reduction area for the specimen shown below.  Does anybody have any suggestions for a smooth way to do this?  Thank you!
Braden
  • 3 weeks later...
Hi Braden,
you have to write your own userdefined check (scalar) via the I-Inspect.
I attach you the screenshot to copy the code.
  1. Switch to the ref.Stage.
  2. Open the creation check.
  3. Copy the code from the actual expression area.
    1. Copy the Number from the green space to the additional input element as a float variable.
4. Transfer your dialog in to the following one.
Greetings, Ivan
