All Around Symbol Without Profile
It's actually a fillet, there is a planar surface between the two fillets. The symbol is on another radius. The title block says ASME and points to a design spec, the spec points to 14.5, no year specified. 14.5 only uses "All Around" with Profile, unless I'm missing something.
The tolerance is huge on the radius, it seems to be transitional between surfaces. the other side of the part is drawn / modeled the same as this side without any dimensions, so my best guess is they meant "TYP". The drawing originated outside the USA, but it does say it is ASME. Probably a "fat finger".
