True Position
Scratching my head here over TP
I have TP of an ID (5.43+/-.03) of 0.4 at MMC. My ID of said hole is 5.458 which is 0.028 under. Do I not add that back to my 0.4?
That in turn should be a Bonus of 0.428. What is calypso doing here by showing a bonus of 0.458? And where is the 0.074 AND the .064 coming from???
Not seeing what software sees apparently. I do not use TP much here where I work so I'm reaching out to the experts
For ID it should be that 0 bonus would be at smallest diameter - so your bonus would be calculated from 5.40 - so 5.458 - 5.400 is your added bonus to TP tolerance 0.4.
Number with (M) is for statistical purposes - i think on report it should be first value with edited tolerance.
But I think it should only add bonus if it's necessary ( if without it it would be out of TP tolerance )
