Additional Printout - Coordinates
Does anyone know how to change the True Position Additional Report in PiWeb to show the two coordinates inside the Position characteristic similar to the older versions of Calypso?
All you have to do is go to
Resources -> Characteristics Settings Editor. Then toggle the drop down and go to Report -> Additional Report. Turn on additional report for any true positions you want to see the additional information for.
Just to clarify, there is no way to make it one line unfortunately if that is what you are after like it shows in the custom report.
The PiWeb reports will break it into seperate lines right below the original true position line.
