[Da...] Posted May 6, 2024 Share Posted May 6, 2024 I having issue getting a program to load. Program was saved on our server and was loading fine last Friday. I go to open the program this morning and I'm prompted with this message. Are there any ideas on how to recover the program? The program is pretty large and id like to save it to avoid having to reprogram it. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 6, 2024 Share Posted May 6, 2024 Shot in the dark, but I'd guess that something got changed/corrupted with either the inspection or inspset files. Hopefully you have another copy or able to revert to another version of it. Link to comment Share on other sites More sharing options...
[Ca...] Posted May 9, 2024 Share Posted May 9, 2024 Was the program saved in a newer version than CALYPSO 2016? If so, programs made or saved in newer versions are not able to be opened in older versions. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 9, 2024 Share Posted May 9, 2024 Look at the contents of a known folder (program) that loads properly, then look at the offending folder. See what's missing. I've had this happen before when running parts across a network path, possibly latency issues. Link to comment Share on other sites More sharing options...
[Th...] Posted May 9, 2024 Share Posted May 9, 2024 Lots of variables with networked program storage. Maybe Richard is right and the inspection file is corrupted. Maybe corporate IT changed the VFS structure over the weekend, which I think also happened to someone on this forum. Are you trying to open this from the quick launch list, or have you tried to open it the long way? Link to comment Share on other sites More sharing options...
[Ja...] Posted May 9, 2024 Share Posted May 9, 2024 Please sign in to view this quote. That's what I was going to ask. My quick launch will not work when I first turn things on in the morning. I have to open it the long way but then the quick launch will work for the rest of the day. Link to comment Share on other sites More sharing options...
[Br...] Posted May 9, 2024 Share Posted May 9, 2024 Sudden disappearance of programs on a network means that either you lost access to the mapped drive or the path has changed. Copy the program to your local drive and run it from there. this will tell you for sure. Link to comment Share on other sites More sharing options...
[Da...] Posted May 9, 2024 Share Posted May 9, 2024 Please sign in to view this quote. I have had corrupted files on the network share several times. Compared to the backup: strange additions from the antivirus software in the inspection file. Link to comment Share on other sites More sharing options...
