[Fr...] Posted November 25, 2021 Share Posted November 25, 2021 Hello everyone, I was asked to create a report based on a comparison between: An analysis made of four samples with the GOM instruments I'm using (Atos ScanPort + Atos Core MV80) The same analysis made by a supplier, with another measuring instrument Obviously, in the second case I only have some PDFs with the results of that analysis. So, my question is: is it possible to create one or several "virtual" (I said virtual because I have no mesh avaiable) new stages in order to import all the data from the supplier and create a complete trend analysis? And if so, which is the best way to do it? Thank you!! Francesco Link to comment https://qualityforum.zeiss.com/topic/571-virtual-new-stage/ Share on other sites More sharing options...
[d7...] Posted November 29, 2021 Share Posted November 29, 2021 Dear Francesco, Unfortunately this is not possible in GOM Inspect. You need measured data from your ATOS sensor to create new stages and actual measured values at the relevant elements in these new stages. Best regards, Matthias Link to comment https://qualityforum.zeiss.com/topic/571-virtual-new-stage/#findComment-1713 Share on other sites More sharing options...
