Scripting - assign parameters in a variable
Hello,
I would like to tune a little bit a script, and the best way would be to use the original "export CSV" gom.script.table.export_table_contents () as an "Interactive command"
Unfortunately some lines after I need to work on the CSV and I need exactly the parameters I put inside of this function, so: is there a way to assign these parameters (like template_name, decimal_separator, etc.) to a variable so that I can use these parameters later on in the script?
At the moment I had to create a customized DIALOG, which is ok and works properly, but I ask, just to know...
Thanks,
Davide
https://qualityforum.zeiss.com/topic/572-scripting-assign-parameters-in-a-variable/
