Did we go back to the days of Calypso being Calapso?
This is getting ridiculous.
Both CMM's, installed by Zeiss and they crash all the time.
Reminds me of pre v3.6 when we called Calypso, Calapso... 🙄
Now I get random errors and my dialog box(s) text is, assuming in German?
You can't close them; all it does is generate a repeating error.
Each time this happens I have to "End Task" Calypso, and it's far too many times.
Ohh. That looks like a fun one. My favorite unrecoverable error is when you are copying and pasting formulas via the feature/characteristic itself, and accidently forget to right click and select formula before you hit paste into the input box. It will lock up the software, and I've never been able to recover short over just force closing the software. Save often is all I can say! 🤣
I can't even continue an interrupted qualification; it just starts all over again.
Also, on qualifications. ("A" angle is rotating around the Z axis, "B" is tilt of the stylus).
If the stylus (B angle) is in the range of 60°-76° (noticed angle ranges of "B" on an adjustable hinge joint) with the Reference Sphere at 180 (+Z axis only) the qualification will not miss the stem of the Reference Sphere but only in the Y axis.
I have not found a way to avoid this collision if I have B beyond 60° less changing "Sphere Coverage" to 140°.
I can't resume our qualification program either. Even if I uncheck Clear Existing, the program still starts back with the Master Probe at the beginning.
