Machine refusing to measure features
Any reason why our machine when running a program in the usual fashion, nothing highlighted, click run, current alignment, from feature list OR characteristic list, it measures the Base Alignment and the first feature only? Then stops and produces a report?
The features are copy and paste of the same thing, with individual alignments in to rotate them around the part.
If I highlight all the features and right click execute, it’s runs perfectly as expected!
You need characteristics for the features or they wont run.
When you duplicated and rotated I assume you duplicated the Characteristics along with the features... are the duplicate Characteristics actually pointing to the new copies of the features or the original ones?
I am 99% certain they do point to the correct feature, not by the machine now so can’t check.
I ticked the tolerance button within the feature, so it automatically created the characteristics, but I will double check, and will try deleting and recalling the feature manually.
