[Se...] Posted April 26, 2024 Share Posted April 26, 2024 Any reason why our machine when running a program in the usual fashion, nothing highlighted, click run, current alignment, from feature list OR characteristic list, it measures the Base Alignment and the first feature only? Then stops and produces a report? The features are copy and paste of the same thing, with individual alignments in to rotate them around the part. If I highlight all the features and right click execute, it’s runs perfectly as expected! Link to comment Share on other sites More sharing options...
[Mi...] Posted April 26, 2024 Share Posted April 26, 2024 You need characteristics for the features or they wont run. When you duplicated and rotated I assume you duplicated the Characteristics along with the features... are the duplicate Characteristics actually pointing to the new copies of the features or the original ones? Link to comment Share on other sites More sharing options...
[Se...] Posted April 26, 2024 Author Share Posted April 26, 2024 I am 99% certain they do point to the correct feature, not by the machine now so can’t check. I ticked the tolerance button within the feature, so it automatically created the characteristics, but I will double check, and will try deleting and recalling the feature manually. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 29, 2024 Share Posted April 29, 2024 You can right-click on the feature that is not running and select check usage to see if there is reason for the feature to run. Link to comment Share on other sites More sharing options...
