Restarting measuring program after a collision in Autorun with Pallet Optimizer Option
Hi everyone,
i've just activated the licence for "Zeiss Calypso Pallet Optimizer" Option and i have a question. 😕
I'm measuring a pallet (24 pallet locations) with optimized stylus change:
Calypso measures all the features that require 1.5mm stylus for each pallet location.
Then it changes stylus system and with this second stylus (1mm) completes the measuring program
measuring the features assigned to 1mm stylus, for each pallet location.
If in Autorun the measurement plan stops at location n.21 out of 24 (due to a collision) while Calypso is measuring with 1.5mm stylus (so for each location only some features have been measured, not all), how I'm supposed to restart the CNC without loosing the measures already done?
If after the collision I click on "CNC start" , Calypso restart the entire measuring program from pallet location n.1, not from 21.
Anyone using Pallet Optimizer knows how to restart the CNC after an interruption?
Thank you in advance,
Hello,
the only way to stop/resume in Autorun is to use the yellow light in the traffic light window. If you red light, you will have to start from the beginning. See page 1211 in the Calypso Basic Manual for more info.
