[Da...] Posted April 22, 2024 Share Posted April 22, 2024 Hello, Is there a way to report each individual feature that is being probed once a pattern is created? I have a pattern of holes being probed and I have a diameter characteristic. It seems that all the diameters are being averaged out and reported under the one characteristic. Can I have a diameter for each circle in the pattern?Screenshot (148).pngScreenshot (147).png Link to comment https://qualityforum.zeiss.com/topic/5814-reporting-individual-features-from-a-pattern/ Share on other sites More sharing options...
[To...] Posted April 22, 2024 Share Posted April 22, 2024 Please sign in to view this quote. Everything looks normal. Why do you suspect the diameter is being averaged out? Have you generated a report and not seen 72 different results? When you open the diameter characteristic, you will only see one result. Not sure if it is first hole or last hole. Link to comment https://qualityforum.zeiss.com/topic/5814-reporting-individual-features-from-a-pattern/#findComment-21520 Share on other sites More sharing options...
[Da...] Posted April 22, 2024 Author Share Posted April 22, 2024 Hi Tom, Not sure if it was just a bug when running the simulation the first time but I am now getting multiple diameters reported on the printout. Thank you none the less Link to comment https://qualityforum.zeiss.com/topic/5814-reporting-individual-features-from-a-pattern/#findComment-21522 Share on other sites More sharing options...
