Autorun, change comment in the Picture (in the frame) if you use Measurement Plan?
Hello,
Is it possible some how to adapt the “comment” text in the Autorun – if I added a “Measurement Plan” and give it a name,
My goal is somehow that I could drive this with a PCM drop down or something, but I would like that the “name” in the “comment” is the same
Name than the PARA-file for example. I would edit it in the .ARN file, but to accept this the Autorun would always need to re-initializat.
Doest anybody know something to manipulate the Autorun Surface a little?
Regards
I don't know if I fully understood your request, but I'm quite sure this is not possible with standard PCM commands. Of course one can always come up with some advanced "executeCode" stuff, but I wouldn't recommend to rely on it too much. These internal functions can change in future versions and if you don't know how to adapt your code, then your process may be broken.
