Formula help needed....
Hello.
I'm needing to define the wall thickness between two diameters.
When I compute the formula below, Calypso states that Diameter_17.9 isn't defined.
I have run the program, so I'm not sure why it states that it isn't defined.
getActual(“Diameter_17.9”)-getActual(“Diameter_16.76”)/(2)
Please help, thanks in advance!
See if this formula works for you. If not it may not like something about the name of your characteristics, I would try changing them to something like Diameter179, just to test if it is the naming causing an issue somehow.
(getActual(“Diameter_17.9”).actual-getActual(“Diameter_16.76”).actual)/(2)
I'll try that formula - Thank you.
I was using the caliper distance and placing the formula in the "x" coordinate location...would be correct?
If you're pulling the diameter from the feature you need to use:
getActual().diameter
if from a Diameter characteristic, which is what I would recommend it's:
getActual().actual
