[Xi...] Posted April 5, 2024 Share Posted April 5, 2024 machine equipped with C98 controller. is it cause communication error ? thank you in advance Link to comment Share on other sites More sharing options...
[Ch...] Posted April 10, 2024 Share Posted April 10, 2024 I would start by trying to restart the SQL Server and the easiest way to do this is by rebooting the PC. You can see that it is running after restart under Services > SQL Server (SDCO) located at C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools. Does this happen when starting CALYPSO or when running one program or multiple programs? Link to comment Share on other sites More sharing options...
[Xi...] Posted April 11, 2024 Author Share Posted April 11, 2024 thank you Charles it happened every week after computer updated to Windows 10 system. most of them occurred on Thursday or Friday. SQL server was running when error popped up. I am doubting if C-98 controller 16Bit board has issue with Windows 10 system? IT department told me there is no APP updates on specific weekday. Link to comment Share on other sites More sharing options...
[Ky...] Posted April 11, 2024 Share Posted April 11, 2024 Hello Xinhu, You said this was a C98 controller? What version of Calypso are you running? Depending on the version, it might be running something that isn't supported on Windows 10. Link to comment Share on other sites More sharing options...
[No...] Posted April 12, 2024 Share Posted April 12, 2024 What does the SDCOError.log say? Please post the error message from the file, this could shed some more light on the problem. Link to comment Share on other sites More sharing options...
[Ka...] Posted April 12, 2024 Share Posted April 12, 2024 Hi Experts, We had a similar problem that Zeiss support could not solve so far. After a long search I found a problem in an upgrade script that M$ executes during updates. The simple solution can be found here, maybe it helps: https://stackoverflow.com/questions/676 ... grade-step Best Regards Karsten Link to comment Share on other sites More sharing options...
[Xi...] Posted April 12, 2024 Author Share Posted April 12, 2024 thank you Kyle the machine is running Calypso 5.6. Link to comment Share on other sites More sharing options...
[Xi...] Posted April 12, 2024 Author Share Posted April 12, 2024 Hi Norbert please see attached SDCO error logs. thank you. Link to comment Share on other sites More sharing options...
[Ka...] Posted April 12, 2024 Share Posted April 12, 2024 Hi Xinhu, Try the settings of the UTF-8 decoding. I remember that we got the same error 0x200 while the SDCO try to connect to the SQL service. Itยดs fast and simple to try ๐ Have a nice weekend Karsten Link to comment Share on other sites More sharing options...
[No...] Posted April 12, 2024 Share Posted April 12, 2024 Please sign in to view this quote. I'm may be wrong, but this doesn't look like the SDCOError.log I was talking about, but more like a general SQL Server log. I was talking about the file specified in the Warning window in your first post: C:\Users\Public\Documents\Zeiss\CALYPSO\config\equip\Prismo_C98\SDCOError.log This file usually contains only the last error encountered. Link to comment Share on other sites More sharing options...
[Xi...] Posted April 12, 2024 Author Share Posted April 12, 2024 hi Norbert there is no error message in: C:\Users\Public\Documents\Zeiss\CALYPSO\config\equip\Prismo_C98\SDCOError.log thank you Link to comment Share on other sites More sharing options...
[Ky...] Posted April 12, 2024 Share Posted April 12, 2024 Hello Xinhu, I'll be honest, I don't know what version of SQL server was in Calypso 5.6, it was a bit before my time, but I would not be surprised if was not supported on Windows 10. This could be just be an issue with compatibility with the operating system. I can't promise that this will work, but what you can try to do is download CALYPSO 2016 (version 6.2 full version), uninstall SQL from that computer, and then install the SQL file in the 2016 installation files. That should at least get SQL to a version that should work on Windows 10. CALYPSO might not like it though, so be aware of the risk. Link to comment Share on other sites More sharing options...
[No...] Posted April 15, 2024 Share Posted April 15, 2024 Please sign in to view this quote. SQL Server 2008, according to the release notes. Link to comment Share on other sites More sharing options...
