Total runtime of machine
Hello!
The lifetime total runtime of machine can also be found by running an ediag. If you're looking for just a one time readout, you can also contact your helpdesk or regional service manager and see if they would be able to pull an ediag and interpret the results with you.
Thanks!
You can found the result of your CMM machine from Zeiss Smart Services or.......
- Close the program Calypso
- Open the program C99 Data Collector Ediag (Start --> Zeiss CMM tools)
- Start the program with the green button
- Wait the results
- Extract the .zip folder created
- Searching the file: D106ltd.txt
In that file you could find the time of working machine and the distance.
