Inclination Angle of Reference Sphere
I'm setting up a measurement plan to scan the reference sphere, and for the purpose of avoiding collisions, I need to know what the inclination angle is. The Ref sphere holder will be set so the laser marks are lined up and the sphere is at an angle (not straight up), the way it came from Zeiss. Does anyone know what that angle is supposed to be? 45 degrees would be my guess, but I want to be sure I'm working from the nominal angle
Generally they come from Zeiss at 135° as that will calibrate most probes.
If you have an RSH Sphere ( Black base) you can set it up to measure the angle, very helpful if you have to set it to specific angles for funky probes.
