GD&T Question again.
We have a customer callout of concentricity from a Cylinder to another Cylinder. Calypso doesn't want to do that. Should we report total runout in place of the concentricity? 😕
Concentricity only applies to a center point, not an axis, so the feature will have to be a Circle. You can use Coaxiality though if you want Cylinder to Cylinder.
Cylinder 1 is the datum, cylinder 2 has the tolerance. I understand the callout is to a circle. I have 3 circles on cyl. 2 , do I report 3 numbers or should I check 3 and find the worst one and only report that 1 ?
