Replace PCM-Parameters in a testplan
Hallo all,
I have a complex test plan with numerous PCM parameters in many measuring elements and test elements. This test plan worked for several months. Now I need to change the name of some PCM parameters. Is there a way to scan the test plan and easily replace these parameters with the new name? At the moment I am looking for these parameters using a function in CALYPSO, creating a screen printout and manually replacing these parameters step by step. This takes a very long time!
Winfried,
There's also a way to find the PCM parameters under Plan - Advanced - Search, if that helps save any time.
