Colors mapping on XY axis
Hello, I need to check a scan relative to the CAD, and I would like to observe the deviations by color mapping only on the X and Y axes, is this possible? if yes do you have the solution please
thank you
Hello,
with a surface comparison you can define a single deviation direction. You could create section with Z-direction, which will show you the deviation in the XY-Plane.
Regards,
Nanno
