Best Fit True Position Graphics in ZX Orientation.
Hi all
When outputting the results of a Best Fit Bore pattern in PiWeb measured in the ZX orientation, the results are shown as a graphical representation in the XY axis. This therefore just shows a blank image of the results. As an overall pattern however, the graphics are presented in ZX.
How can I get Calypso to output the individual hole results in the ZX axis?
Help on this would be greatly appreciated.
Please see images.
Matt
Let's make an #MyVoice call for adding orientation into Calypso window - there is scale so why not orientation, right?
Since you can not really set fixed orientation in template ( you can I think, but then other plots will be changed as well )
  • 1 month later...
Your graph/Plot appears to show ZX.
The upper right corner trihedron is Z and X.
Your graphical layout is in X across the top and Z from top to bottom at the right.
Or is that something you made for show and tell?
I believe he is saying that when its a BFBP it displays correctly, but when it's a single feature position it doesnt.
