[Sc...] Posted December 9, 2019 Share Posted December 9, 2019 Hello all, While running the automatic qualification program on Sunday it stopped on one probe(3.0mm x 50mm) and gave the error message of "205 Command/macro=syntax error or unknown expression". I still could run the probe as an individual check and it would finish and give the stylus date and sigma value (that were good .000009"), but trying to run in the program with 1 or more other probes resulted in it stopping, the stoplight going to red, and not qualification date or sigma value for the tip. All other probes ran through without issue giving and updated qualification date and good sigma values. Anyone seen this before or thoughts?? TIA, Scott Edit: To clarify this auto qualification program has been running successfully before already (we run this every 7 days or less). This is the first time it's ever stopped like this with the error message. Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/ Share on other sites More sharing options...
[Ky...] Posted December 17, 2019 Share Posted December 17, 2019 Scott, The same issue just started for me as well with existing programs. Have you had any success finding the source of the error? Kyle Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22690 Share on other sites More sharing options...
[Sc...] Posted January 6, 2020 Author Share Posted January 6, 2020 Kyle, After speaking with an Applications Engineer on the Zeiss help line he suggested updating our service pack, as we were three back on the 6.6 (2018 Calypso). To date we haven't seen this again, and shortly we'll be updating to 2019 so hopefully this has eliminated the issue. He did note that he looked (some) for the specific error and couldn't find anything specific on it and based on our conversation noted the service pack update should (most likely) take care of it. Scott Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22692 Share on other sites More sharing options...
[Ri...] Posted January 11, 2022 Share Posted January 11, 2022 I not sure this is a service pack issue. I'm on v7.0.12 and this "Command 205/Macro" problem comes up. I have noticed it tends to come up after running subsequent evaluations for me. I just dealt with it this morning and ended up replacing the program with a saved file from our CMM Vault. Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22694 Share on other sites More sharing options...
[Me...] Posted June 2, 2022 Share Posted June 2, 2022 I am on the latest version and service packs, replaced the program with a new copy from our system and still getting this error message. Have anyone had any success finding the source of the error? Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22696 Share on other sites More sharing options...
[Ke...] Posted March 21, 2024 Share Posted March 21, 2024 Ok...TF... I'm running 2021, and have been for quite a while... This error just popped up for the first time, when trying to execute a run from the Start Alignment. Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22698 Share on other sites More sharing options...
[ni...] Posted March 21, 2024 Share Posted March 21, 2024 Hi, i've also this error, for me this is the left jostick of the control panel who is sick. I've swith the control panel between the two MMT, and the error folow the control panel ... pupitre.JPG Link to comment https://qualityforum.zeiss.com/topic/5988-205-commandmacro/#findComment-22700 Share on other sites More sharing options...
