Measuring points save files
Hi,
When the save measuring points option is checked, where does that data sent and saved in regards to a folder. The feature has been turned on for a ton of programs and I wanted to clean it up some to add space. Probably small files but nonetheless...Thanks.
a quick way to delete them is to go to the directory in windows explorer where all the programs are that have measuring points you no longer need.
search ".zmp"
Delete everything that comes up.
They do actually amount to a fairly significant amount of space being used. Be careful doing this as your success here will be determined by your file structure organization. I organize by part number, so I know that all programs for a given part number are done and can be archived.
If everything is just in one directory you'll delete the measured points for everything.
Hey Joey. Mike's recommendation is correct.
And thanks for the idea. I've got 10 GB of measuring points on my HD.
