Lost Data
We had a new program that we ran a gage R&R on, 3 operators running 10 parts, 3 times each. Sadly, the program was not set to output a table file. Is the data from the runs stored somewhere and can be recalled/reloaded or something? It's over 3 hours of labor to re-measure them.
Thanks,
Andrew
Only if you have Measuring Points turned on under Resources > Results to File. If so, then you should be able to go to Plan > Subsequent Evaluation to load the individual runs. Our template program has this automatically enabled for when we program new parts, so we don't forget.
