Marked Characteristics in table reports
I have a routine where I'm outputting two reports, one with all the characteristics and another that is only outputting the ones I have marked OFF. Is there a way to have only the ones marked off show up when I do a PiWeb table report so I don't have to manually do it every time?
Thanks,
Mike
You would need to create a custom table report, so that you can do this any time you'd like, but the only change you'd need to make is to set a Characteristic filter on the Protocol with the Condition: Control item = No.
  • 2 weeks later...
i have the same problem and this manipulation doesn't work .... the characteristic mark appear on a table ....
someone have other idea ?
Hello,
The above solution was to show marked characteristics in the report. If you don't want to show marked characteristics in the report, that is where you'd enable the "Hide (selected characteristics are not displayed)" inside of the Multiple Report tab. Please ensure that the characteristics are indeed Marked.
I finally got back to this project and got this to work. The only difference is I had to set my control to yes instead of no but I got what I needed in the table report. Thanks again for your assistance.
