How to export points from gear pro into solidworks
Please help.
Could someone please explain to me how to export my actual point results from Gear Pro so that I may import them into Solidworks? And what module do I need in Solidworks to perform this?
Thank you for your assistance.
Heather,
Great question. I'm not sure it's entirely possible as simply export CAD with actual data, etc.
Are you referring to a standard spur gear or spline, or rather a bevel gear ?
I have done a lot of topography 'twist' measurements on standard spur gears, and have output the data in an excel format ( that is another topic but there is info in the help manual )
Our guys have complex Gleason and other software to model actual CAD files based on excel, etc.
For bevel gears, I believe there is a roundabout way to do it in GearPro.
I can save an .act file as a "nominal" file for a spur gear - and then produce a CAD on the screen, however I doubt it has the flank errors modeled in the CAD, rather perhaps populated in a text file for next results comparison, etc.
I'd suggest reaching out the Gear Pro team, and let us know if you find anything.
This is actually a great idea for new functionality (request on MyVoice portal), however I think they would really need to upscale their modeling kernel in the background, which may be in the works.
Best of luck !
  • 4 weeks later...
Heather, you can output to excel in a variety of formats/outputs.
I would know where to begin to import this so it is meaningful in Solidworks.
In theory, you would select your gear flank in solidworks and make it some kind of a 'curve point' file. Then upload the excel to give it actual data, etc.
Good luck.
