Construction of Features
How do I create a BHC (bolt hole circle) from many circles? Basic user here. Pcdmis experience - whereas you simply construct them and go. Already have pgm for hole position but can't seem to find how to tie these together for the BHC. Thanks!
You do simply construct it and go, if you only focus on how it's different from DMIS you'll hate Calypso. Take a training course and you'll appreciate a lot that Calypso has to offer.
Create a new circle feature, then recall the circles that make up your bolt circle. Recall will use the center points of the calculated circles, so make sure you have the correct evaluation settings for those circles set.
In this case, it's recall, not recall feature points that you would use.
