Piweb Monitor is only showing last result?
For some reason Piweb monitor is only showing the last result even though last measurement only is not activated. Any ideas?
I have attached a picture showing issues. If I select last 300 or use date from ... to it still only shows 1 result.
  • 2 weeks later...
I would test with a different template to see if you run into the same issue or try a different database/program.
Then go from there accordingly. Could be a filter or improper databinding if it is a custom template.
This is correct. Up to 10 per program with PiWeb Basic.
Up to 1000 per program with PiWeb plus.
