[Br...] Posted December 13, 2023 Share Posted December 13, 2023 Since updating to version 8 of PiWeb there is now a Text Element at the end of the report for Approval or adding changes. Is there a way to disable this from appearing on the reports?Text Approval.JPG Link to comment Share on other sites More sharing options...
[To...] Posted December 13, 2023 Share Posted December 13, 2023 Please sign in to view this quote. Yes, but it requires you to modify the template. Go into Multiple Report window and click the Pencil Icon at middle right. Click Generic Templates and save the template as StandardProtocolBackup (this will make sense later in the post) or whatever name you want. Make note of the location of where the template is stored. PiWeb designer will open. If not, check the task bar at the bottom and click it to bring it up. Click the Page Structure tab on left side. Click the small triangle next to Protocol to open up the list. Scroll down and select Protocol footer at bottom. Click Properties tab at left. Un-tick Output (Monitor) and Output (print) options. Click save. Close editor. You should be back at Multiple Reports window. Click the Monitor icon at top to see what report looks like. You will need to select this template for any program that you want to use this report. To make it the default template for any program, old or new, you will need to move or copy this template from the place you saved it to the default location, C:\ Program Files (x86)\Zeiss\Calypso X.X\ PiWebReportingTemplates. My suggestion would be to save your template with a special name, i.e. StandardProtocolBackup.ptx because anytime you update the software, StandardProtocol.ptx will be overwritten with original file, thus loosing your template. If you save it with a unique name, it will remain after the software update. You will just need to delete the StandardProtocol template. Copy and paste YOUR template. Rename the copy to StandardProtocol. That way you'll always have your original modified template. If you're old enough and know DOS and how to write a batch file, you could automate this process. Link to comment Share on other sites More sharing options...
[Br...] Posted December 13, 2023 Author Share Posted December 13, 2023 Great! Thank you very much Tom, it was really starting to aggravate me! Link to comment Share on other sites More sharing options...
[hu...] Posted February 29 Share Posted February 29 I just tried to do this, and it still shows the text approval box at the end of the piweb report.... Link to comment Share on other sites More sharing options...
[To...] Posted March 1 Share Posted March 1 Please sign in to view this quote. .... Click Properties tab at left. Un-tick Output (Monitor) and Output (print) options. Click save. .... Please post screenshot of Properties tab showing where you un-checked the Output options. Link to comment Share on other sites More sharing options...
[hu...] Posted March 1 Share Posted March 1 I attached two files.Capture1.PNGCapture.PNG Link to comment Share on other sites More sharing options...
[Je...] Posted March 1 Share Posted March 1 Please sign in to view this quote. Review the ZEISS PORTAL KNOWLEDGE BASE for a step-by-step article on how to resolve this. Link to comment Share on other sites More sharing options...
[hu...] Posted March 1 Share Posted March 1 ok. Im in ZEISS PORTAL KNOWLEDGE BASE, what is the article under? Link to comment Share on other sites More sharing options...
[Da...] Posted March 4 Share Posted March 4 the article is under "PiWeb -Suppressing the dialog box at the bottom of the...." Link to comment Share on other sites More sharing options...
[To...] Posted March 4 Share Posted March 4 Please sign in to view this quote. You selected the Footer section. You should have selected the Protocol Footer in the Protocol section. See below,Protocol Footer.JPG Link to comment Share on other sites More sharing options...
[hu...] Posted March 4 Share Posted March 4 Thank You. it worked. Link to comment Share on other sites More sharing options...
