[Jo...] Posted February 29, 2024 Share Posted February 29, 2024 Hi, I cut a section of a model and created a feature curve and line for intersecting. I scanned both features. You can see where Calypso created the nominal intersect point. It wouldn't calculate a result for me this time, but it has worked for me in the past using similar method. I tried to project both curve and line onto a same plane in YZ to maybe force the issue but still no result. It doesn't give me an error, just no result. It looks like it wants to calculate briefly, but doesn't populate the actuals. Better method for doing this?intersection.jpg Link to comment https://qualityforum.zeiss.com/topic/6124-intersection-2d-curve-line/ Share on other sites More sharing options...
[Cl...] Posted February 29, 2024 Share Posted February 29, 2024 The curve looks like a line. Why not measure both as lines? Link to comment https://qualityforum.zeiss.com/topic/6124-intersection-2d-curve-line/#findComment-23488 Share on other sites More sharing options...
[Ma...] Posted February 29, 2024 Share Posted February 29, 2024 Use projection plane, or instead of 2d line use plane ( can have nominal start points from 2d line ). I am guessing they are not on same plane. Link to comment https://qualityforum.zeiss.com/topic/6124-intersection-2d-curve-line/#findComment-23490 Share on other sites More sharing options...
[Jo...] Posted February 29, 2024 Author Share Posted February 29, 2024 It's a curve but does look like a line. I did try that but it gives me the same no result along with terrible form.. Link to comment https://qualityforum.zeiss.com/topic/6124-intersection-2d-curve-line/#findComment-23492 Share on other sites More sharing options...
[Je...] Posted March 1, 2024 Share Posted March 1, 2024 Please sign in to view this quote. Based on what is shown here, this is just a case of using the wrong features. A Curve does not project beyond its measured data. All calculations come from the existing measured points only. You cannot intersect with a Curve where there is no measured data. Recall the relevant Curve data points into a 3D-Line to get the intersection to calculate. Link to comment https://qualityforum.zeiss.com/topic/6124-intersection-2d-curve-line/#findComment-23494 Share on other sites More sharing options...
