[Er...] Posted December 30, 2021 Share Posted December 30, 2021 (edited) Hello, Is it true that angle measurement according to ISO 14405-3 is not supported yet? If so, are there any plans to do this in the near future? Best regards, Erik de Lange Edited December 30, 2021 Link to comment https://qualityforum.zeiss.com/topic/614-angle-measurement-according-to-iso-14405-3/ Share on other sites More sharing options...
[Ch...] Posted January 3, 2022 Share Posted January 3, 2022 Hello, this feature has been added with GOM Software 2021. The new checks can be found in the GD&T section of our I-Inspect tool. If you want inspect angular size on other elements as a cone you have to create a specialized fitting element first (similar to the creation of linear size on parallel planes). This new element is called Wedge. Construction could be something like this Create Plane A in both nominal and actual Create Plane B in both nominal and actual Create an Wedge (Construction->2-Plane-Wedge) on Nominal using your nominal plane Create the actual Wedge using measuring principle "Referenced construction" Select the nominal wedge in the explorer and use the GD&T section of the I-Inspect tool to create an angular size. Hope this helps, Christoph Schult Link to comment https://qualityforum.zeiss.com/topic/614-angle-measurement-according-to-iso-14405-3/#findComment-1840 Share on other sites More sharing options...
[Er...] Posted January 3, 2022 Author Share Posted January 3, 2022 This is fantastic! Thank you Christoph! Link to comment https://qualityforum.zeiss.com/topic/614-angle-measurement-according-to-iso-14405-3/#findComment-1843 Share on other sites More sharing options...
