What are the advantages of tolerancing curves within the feature?
Hello.
I was wondering, what are the advantages or applications of tolerancing curves from within the feature rather than from a characteristic? I know this, of course, but I just wanted to make sure YOU know it 😉 🤣
The only use I've had for it is Segmented Tolerances.
I used to work on a lot of sprocket teeth that had different tolerances for different zones, so it was easier to tolerance the Curve and then you can have the Line Profile or Curve Form Characteristic reference those tolerances.
