Approach clearance plane cannot be reached error
Hi.
I´ve planned on doing some changes to my program offline. But when i try to run the program offline i get this warning message.
In the CMM the program works fine.
I don´t have any blocked edges set. And the BA is set to zero.
Does anyone know what i can do to get this to work offline aswell. Thanks in advance
// Hannes
There's a button in the simulation window, I think it's the rightmost in the bottom row. With this you can move and rotate your part relative to the CMM. Make sure to keep "drag base alignment" checked all the time.
However, I have no experience with how to handle a rotary table in Planner.
