[Ha...] Posted February 22, 2024 Share Posted February 22, 2024 Hi. I´ve planned on doing some changes to my program offline. But when i try to run the program offline i get this warning message. In the CMM the program works fine. I don´t have any blocked edges set. And the BA is set to zero. Does anyone know what i can do to get this to work offline aswell. Thanks in advance // Hannes Calypso_clearance_error.PNGFetching info... Link to comment Share on other sites More sharing options...
[Mi...] Posted February 22, 2024 Share Posted February 22, 2024 Go to: Plan-->Navigation-->Block edges.. How is the block? Link to comment Share on other sites More sharing options...
[Ha...] Posted February 22, 2024 Author Share Posted February 22, 2024 It looks like this. I haven´t check any boxes. Link to comment Share on other sites More sharing options...
[Da...] Posted February 22, 2024 Share Posted February 22, 2024 Try setting up your part in the center of the machine volume in offline-mode. Maybe you are too close to the virtual edges of the machine volume. Link to comment Share on other sites More sharing options...
[Ha...] Posted February 22, 2024 Author Share Posted February 22, 2024 I feel like i may have found a root cause of the issue. It seems like my RT-axis is way out of position. How can i move the part in the offline environment like u suggested? Axis_pos.PNGFetching info... Link to comment Share on other sites More sharing options...
[Cl...] Posted February 22, 2024 Share Posted February 22, 2024 Do you think that the rotary being out of position is the reason for this? Do you have PCM? Place this in your post settings. It will return the rotary to zero. rotateReference(0) Link to comment Share on other sites More sharing options...
[Mi...] Posted February 22, 2024 Share Posted February 22, 2024 Maybe could be the problem with rotable table. But, when you added the file CAD for the first time, you flipped the CAD like your thinking BaseAlignment with CAD-->Modification-->CAD Model Transformation? Link to comment Share on other sites More sharing options...
[No...] Posted February 22, 2024 Share Posted February 22, 2024 Please sign in to view this quote. There's a button in the simulation window, I think it's the rightmost in the bottom row. With this you can move and rotate your part relative to the CMM. Make sure to keep "drag base alignment" checked all the time. However, I have no experience with how to handle a rotary table in Planner. Link to comment Share on other sites More sharing options...
[Mi...] Posted February 22, 2024 Share Posted February 22, 2024 Another thing to try is Resources>Utilities>Set Base Alignment to zero If anything about the Base Alignment has changed you will often have to select that in planner. I similarly have no experience with a rotary table in planner. Link to comment Share on other sites More sharing options...
