Measuring Diameter on Cone (Cosine error)
Hi,
I'm using a Duramax with a z-down probe measuring the diameter on a cone with a target height. I know the machine will probe normal to the surface. The question is:
Is the height specified on the dimension box the low point of the probe or the tangent point? Is there cosine error associated with this measurement?
Thank you for the help.
If you specified the correct cone angle (that is, the actual angle of the part, not the theoretical nominal!), then it shoulld be the tangent point. Otherwise there might be a cosine error.
I have only had success using cone calculation for this type of measurement. Circle on a cone is pretty difficult to get right, and a simple circle will not work. Probe the cone as a cone and then select cone calculation and specify where you want the diameter, OR the position. Works like a charm!
This.
scan that cone as a cone. Then cone calculation will give you the diameter at a specific height.
or it will give you the distance at a specific diameter.
works amazing.
