[ZE...] Posted April 28, 2023 Share Posted April 28, 2023 CALYPSO 2023 introduces a new GD&T Library for form and location. The version is in the development process and has not yet been released for productive use. The new GD&T Library can be activated for tests in CALYPSO 2023: Tools / Settings / Miscellaneous / Licenses => "GDT_Engine_Beta" Pay attention to the warning "only for testing"! During the test phase, the previous and the new GD&T Library can be used in parallel in a measurement plan. After the end of the test phase (expected CALYPSO 2024), you have to select either the previous or the new GD&T Library for GD&T for new measurement plans. Videos are available in the ZEISS Academy https://portal.zeiss.com/academy/video-tube/imt/87496 EN) CALYPSO 2023 – New GD&T Library https://portal.zeiss.com/academy/video- ... trEwZ-7yq- Link to comment Share on other sites More sharing options...
[Ro...] Posted May 1, 2023 Share Posted May 1, 2023 cool Link to comment Share on other sites More sharing options...
[DW...] Posted May 1, 2023 Share Posted May 1, 2023 Phone call to tech support? Also, perhaps editing out some of your personal information before someone signs you up for things you dont want.. 🤣 Link to comment Share on other sites More sharing options...
[Ro...] Posted May 1, 2023 Share Posted May 1, 2023 Please sign in to view this quote. Done and done. Thank you Link to comment Share on other sites More sharing options...
[Ap...] Posted September 15, 2023 Share Posted September 15, 2023 In order to see how you deal with the datum and profile issues below, the 2023 beta was installed. viewtopic.php?t=11544 Surprisingly, the measured "freeform" feature is no longer available for SURFACE PROFILE analysis? Link to comment Share on other sites More sharing options...
[Ap...] Posted November 13, 2023 Share Posted November 13, 2023 To be more specific regarding to "freeform", it can be selected for analysis in "surface profile" with version QA-STAT Interface 2.0.2.0 (7.6.00) but it CANNOT be selected for 2.0.2.2, service pack1. Link to comment Share on other sites More sharing options...
[To...] Posted February 16, 2024 Share Posted February 16, 2024 Starting to play around with new GD&T library and noticed that on a Roundness, Cylindricity, Flatness and Straightness characteristics, the default evaluation is not Minimum Feature (Chebyshev). It uses "Default" evaluation. Is there a place to set the "Defaults"? Any news on the missing Freeform Surfaces option for Surface Profile? Link to comment Share on other sites More sharing options...
[Ky...] Posted February 16, 2024 Share Posted February 16, 2024 Hey Tom, I'll be honest, I never really thought about it until now, but doing some testing I haven't been able to find a way. If you press F1 in that menu, it says that default should refer to the feature's evaluation, but based on my testing that doesn't seem to be the case. I've also tried using save/load defaults and it doesn't seem to affect it either. As far as I can tell, I don't think there is a way, but I am doing some digging. If I find anything of use, I'll post it here. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 19, 2024 Share Posted February 19, 2024 Please sign in to view this quote. Tom, You cannot just look directly at the Feature Evaluation from inside the Characteristic like you did in the past. You have to look at the Computation Method(s) by clicking on the lightbulb down at the bottom next to the Actual. Link to comment Share on other sites More sharing options...
