Probe Calibration Program
How do I set up the Calibration Sphere in the probe calibration program, also will I need a base alignment and a clearance cube?
I use current align and use position points under the Navigation To Feature drop down box.
You have to reference the cal sphere first so the machine knows where it is, and what angle its set too. Then you will make the probe qual prg from Resources-Utilities-Probe qualification.
I have a PDF of this somewhere. See If I can find it..
@Racine Mike Do you have any others pdf files like this ? I mean any manuals. It would be much appriciated if you could send me via email danielstawiarz@gmail.com Thank you in advance !
  • 5 years later...
