[Ar...] Posted January 6, 2022 Share Posted January 6, 2022 Guys please help me. I can't select a bigger surface component than show attached. What should i do? I have tried to select by my own but when i select a bigger surface the program get back to this surface in green. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/ Share on other sites More sharing options...
[Iv...] Posted January 6, 2022 Share Posted January 6, 2022 Hello Artur, did you try to edit the creation parameters or is this image showing the creation of a new surface? A wider screenshot would be easier for the understanding. The squares indicates that facets are found. So normally the SW can calculate the surface. Greetings Ivan Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1868 Share on other sites More sharing options...
[Sa...] Posted January 10, 2022 Share Posted January 10, 2022 I am have the same issue. It appears to only create a surface in the positive x, positive y quadrant. Have you found a solution? -Sam Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1898 Share on other sites More sharing options...
[Iv...] Posted January 12, 2022 Share Posted January 12, 2022 Hello both of you, can you provide me the projects you have with this issue under following transferlink; https://filetransfer.gom.com/support Please use as subject following case number: CNR-70872-W7P3Q8 Greetings, Ivan Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1917 Share on other sites More sharing options...
[Sa...] Posted January 12, 2022 Share Posted January 12, 2022 Hi Ivan, Thanks for the response. Here is a screenshot of my project. I also sent the project using the link above. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1923 Share on other sites More sharing options...
[Iv...] Posted January 13, 2022 Share Posted January 13, 2022 Hi Sam, i can't reproduce the missing visualization with your project. You just go into the create surface dialog and select your area and change the current visualization into pattern quality? This is my result: I used the latest SW 21 Hf3 Version. Which one did you use? If it's a newer one i would recommend to update your SW. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1924 Share on other sites More sharing options...
[Sa...] Posted January 13, 2022 Share Posted January 13, 2022 Hi Ivan, I don't have any updates available, so I assume that means I am on the most current version? When I go into the create surface dialog and select your area and change the current visualization into pattern quality, I do not have the same result. Any other ideas? Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1930 Share on other sites More sharing options...
[Iv...] Posted January 17, 2022 Share Posted January 17, 2022 Hi Sam, so it seems that the SW Version is not the cause. Can you check the properties and tell me if you unboxed the Texture? Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1939 Share on other sites More sharing options...
[Sa...] Posted January 19, 2022 Share Posted January 19, 2022 When I toggle the texture box, the display only changes from gray to the image. The size of the element does not change. The size did mysteriously change in between opening the files though. However, the surface size is still not complete. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1949 Share on other sites More sharing options...
[Iv...] Posted January 21, 2022 Share Posted January 21, 2022 Hi Sam, can you please screenshot the next time also the explorer on the left side to have a better view on which inspections and elements are currently visible. Can you repeat the creation of an surface with those settings and please set everything else previously invisible. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1960 Share on other sites More sharing options...
[Sa...] Posted January 21, 2022 Share Posted January 21, 2022 Hi, Sure. here is a screenshot during the creation of a surface. Notice how only the positive x and y are are as slightly different color. and and here is after creation: Here is with texture toggled on: And when I go to view some measurement (in this case displacement), only the positive x and y are shown: I did a full uninstall and reinstall and the issue persists. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1962 Share on other sites More sharing options...
[Al...] Posted January 24, 2022 Share Posted January 24, 2022 Hello all, It seems the display of the surface component restricts the area. However, when you display the 3D measure view, all the surface you have created appears. Can you confirm ? I suppose the issue only affects the display mode when you choose your surface (images superimposing), but is not considered when computing the surface strains. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1970 Share on other sites More sharing options...
[Sa...] Posted January 24, 2022 Share Posted January 24, 2022 Hi Alban, Thanks for chiming in. However, I do not think that is not the case. As you can see in the last screenshot I posted, only the displacements in the small, upper right section are shown, this is the same case for strains. Am I misunderstanding your suggestion? Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1982 Share on other sites More sharing options...
[Al...] Posted January 25, 2022 Share Posted January 25, 2022 Hi Samuel, If you draw an asymmetric surface (not a square), you will see all the surface is shown in the 3D view (as shown by the pictures I have uploaded). It seems to mean the software take into account all the surface for the strain computation. However, and I agree with you, if you want to superimpose both the speckle and the strains computed, only the left upper quadrant of the strains is shown. A solution can be to move the origin to the bottom left corner, but I don't know if it is possible without having to create a surface. Alban Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-1991 Share on other sites More sharing options...
[Iv...] Posted January 27, 2022 Share Posted January 27, 2022 Hello together, i forwarded the issue to our software department. It seems there is a rendering problem for the visualization of the pattern quality in 2D projects. If i receive more information i will let you know. But in fact that problem occurs only during the visualization or preview of the stochastic pattern afterwards you receive a full and right component. Greetings, Ivan Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-2014 Share on other sites More sharing options...
[Mi...] Posted March 3, 2022 Share Posted March 3, 2022 (edited) Hi everyone! I experience the same problems. The surface component only seems to be active in the positive y and x axes of the images (figure 1 & 2), even if I select a bigger area. However, the 3D measuring view does show the entire sample (figure 3). Any ideas on how to solve this issue? Edited March 3, 2022 Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-2225 Share on other sites More sharing options...
[Iv...] Posted March 8, 2022 Share Posted March 8, 2022 Hello together, the issue is fixed. The fix will be part of the next hotfix 5. Greetings, Ivan Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-2243 Share on other sites More sharing options...
[Mi...] Posted March 8, 2022 Share Posted March 8, 2022 Great, thanks for the reply Ivan! Any idea when the next hotfix 5 will be released? Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-2244 Share on other sites More sharing options...
[Iv...] Posted March 9, 2022 Share Posted March 9, 2022 Please sign in to view this quote. The release date will be around the first weeks in April. So about one month. Link to comment https://qualityforum.zeiss.com/topic/623-cant-not-select-a-bigger-surface-component/#findComment-2246 Share on other sites More sharing options...
